dukenukem
Apr 29, 2016Explorer
Problem filling fresh water tank
I have a 2005 American Tradition and removed the winter cover and started getting it ready to travel. Everything worked without issue last year, winterized it and went to fill the fresh water tank and water will not go into the tank. Started with the fill outlet on the side of the motorhome and a few gallons go in then water comes out of fill pipe and the small vent tube next to fill pipe. Then hooked hose up to city water connection and switched valve to fill the tank and same thing happened. Can follow the fill pipe underneath until it enters the top of the tank (can't reach it though) and all looks well. Poured hot water into the fill pipe to see how far down the water flows to determine if there was a blockage in the pipe and it was warm all the way to the tank inlet.
All worked fine when put away for winter. Any thoughts would be greatly appreciated.
Thanks
Thanks
