Feb-25-2017 07:30 PM
Feb-26-2017 07:56 PM
dougrainer wrote:
It sure looked like the Metal finger gasket. As to 10 hours, NO OEM has any gasket that would require 10 hours to do the job. In your case, You would remove the inside upper wood Fascia and back support(about 1.0 hour total r&i) and that would give you access to clean off the old gasket and install the new gasket. IF you have a Slide cover, you remove it(1.0 total to remove and reinstall), That gives you outside access to facilitate removing and installing a new seal. probably 4 hours total but the OEM probably pays no more than 3 hours if even that. Most will not go over 2.0 for just a top wipe/gasket seal. And, YES, I have probably replaced at least 200 slide seals in the past 20 years on all various makes and models. Doug
Feb-26-2017 11:48 AM
Feb-26-2017 10:46 AM
WNYBob wrote:
You all know what professional means someone that gets paid to do a job
where as an Expert knows what he is doing.
Feb-26-2017 09:51 AM
dougrainer wrote:creeper wrote:dougrainer wrote:
I think the OP is mistaken. I would NEVER call most of the people that work at a CW in Service, Professional or Experts. You get what you pay or go to. Doug
PS, THAT type seal can NEVER be reinstalled. Once the metal fingers have pulled loose like the pic, it will never lock on the metal track again.
There is no metal fingers to lock into. It's simple flat surface held in place with 3m tape. The key is to removing ALL the old gasket, which is also the hardest part.
The 2nd problem is that they did not use the correct seal. The correct part is a triangle seal, so when the slide open all the way and drops down the triangle point is the only thing that moves. They used a bulb seal and when the slide drops down the whole seal moves and pulled loose. The 3rd problem is the correct seal actually sits on top of lip and because of the correct parts size you have no option other then install it straight and it then has support. Their roller coaster install was because of their incompetence of using the wrong part. There is no substitute for using the CORRECT parts, rather then some
Feb-26-2017 09:38 AM
Feb-26-2017 08:41 AM
Feb-26-2017 05:26 AM
Feb-26-2017 04:19 AM
Feb-26-2017 04:05 AM
Feb-26-2017 03:34 AM
Feb-26-2017 02:53 AM
Feb-25-2017 08:52 PM
darsben1 wrote:Bruce Brown wrote:
Picture A, Camping World.
Picture B, you.
99% chance I'm right, yes? :B
I agree with you
Now I wonder if there are extra points for guessing which Camping World.
Feb-25-2017 08:13 PM
