PCarnathan's avatar
PCarnathan
Propane for grill from RV
We have a 2009 Mandalay 43A. I bought a propane grill from Camping World as well as a flexible hose so I could run the grill using the RV's propane tank. The hose's quick disconnect plugged perfectly into the RV's receptacle and I turned on the RV's valve. Sadly, there's not enough gas coming out of the hose to light the burners. As a test, I tried a brand-new small canister of propane and the grill fired right up.
Currently, the RV's propane tank is about 1/4 full. Could that be the issue? I don't know of any other valves in RV's propane system. Can you think of anything I'm missing?
Many thanks in advance,
Pat in Menifee, CA
www.patcarnathan.com
