DoubleVeteran
Jun 26, 2017Explorer
Proper way to hand crank out Roadtrek awning?
Hi all,
I picked up a 2011 Roadtrek popular 190 last week and took it out camping this weekend. I tested everything at the dealer and he showed me how to open and close the awning. Crank it all the way out, (it kinda hangs out pretty far...) then extend the side support poles to the side of the RV, or the ground. I did this at the campground, and it worked find the first time. I closed it at night, and when I did the same deployment method the next morning, the left side bracket that holds the awning (crank side) broke off! I checked the bracket and it is only held on by three short screws from the inside of the RV that only go about 1/8" deep into the bracket (which is the thickness of the bracket).
So now I need to fix this, and I'd like to know if the method I'm using to open the awning is correct?
Thnx,
DV
Thnx,
DV
