Empty_Nest__Soo's avatar
Nov 24, 2015
Question for thos using Ready Brake
I’m setting things up to tow our new car. It will be the first time I’ve towed 4-down. I’ve purchased the Ready Brute Elite tow bars, the one with the Ready Brake surge brake system built in. I’ve made arrangements for the dealer where we bought the car to install the base plate and the cabling for the Ready Brake, as well as the cable for the break-away brake. Now that I’ve received the items I ordered, I have a question:
The Ready Brake came with an "In-Dash Indicator Light," which is supposed to light up when the Ready Brake applies the brakes on the towed car. Installation of this Indicator Light involves drilling a hole thru the dash, tapping into a 12-volt source which is hot when the ignition is on, and running a supplied wire from the rear of the coach to under the dash to connect to the light. Given the season here (cold), I’m wondering whether it is worth the bother for me to crawl around under the dash and under the chassis running this wire, or paying the dealer to do it.
As near as I can tell, the light will be lit-up by the movement of the little arm that actuates the cable to apply the brakes on the car. If I were to do something foolish like adjust the brake-actuating cable too tight, or forget to hook it up when getting ready to tow, I don’t see where this light will alert me to something gone wrong. It looks like it will only light up when the mechanism is trying to apply the brakes in the towed car, not the actual application (or lack thereof).
I’m not persuaded that the bother or expense of installing this light adds much value. I am inclined to not bother with installing it.
Am I missing something?
Thanks,
Wayne
