Liltippy
Nov 22, 2013Explorer
"Tee" from propane tank to gas grill
Any suggestions on how best to run a gas line from the built in LP tank to a gas grill?
I have looked at the "Camco 59103 RV Propane Brass Tee with 3 Ports and 12' Hose" as a possibility.
I does look like I would remove the cover on the regulator on the tank on the coach to install this "tee" before the regulator. If you have done this, is there room to reinstall the regulator cover?
Any suggestions or your experience would be helpful.
Thanks
Thanks
