conceptumator
Mar 25, 2015Explorer
Rear View a Mirror a Repair
OK, folks - I could really use some advice from your experiences with this issue. I have a 2006 Hurricane 30Q with mirrors mounted on either side, just below the front windows. From the fab drawings I have, there is a 6" high x 1" thick piece of plywood blocking in the wall for mounting of the mirrors. A few months ago the passenger mirror was loose and wouldn't tighten up. I found that water had seeped in around the mounting screws and played havoc with the blocking. At that time, I was able to drill out the holes slightly larger and add some threaded inserts to which I mounted the mirror. Now it seems my repair is failing and I need to do something else. I've thought about putting a plate inside the coach and thru bolting but it's really hard to access that space. Thoughts or suggestions? Thanks in advance for anything you can lend to the conversation. Have a nice evening.
