FIRE_UP
Aug 19, 2014Explorer
dreamer wrote:
I ran over a piece of truck tire in the road, I was able to straddle it but after that I noticed my rear view wasn't working. I don't know if these two events are related or not. When I got home and started backing into the port, I noticed the rear view WAS working. It only works when the transmission is in reverse.
I've climbed under and looked for anything obvious like some wires loose etc but didn't see anything.
Any ideas? I'm searching for any manual I might have for the rear view system. Thanks.
dreamer.
dreamer,
Depending on "who" made your system and, just how they wired it, most cameras and monitors are triggered by two power sources. The first being, IGNITION ON and, the second is when the coach is put into reverse. And, the reverse or, back up light switching system is what does the actual triggering of it. Now, first off, based on how you're wording your original post and, what you're asking, it sounds as if your system "used" to work normally while motoring down the road but, it now ONLY WORKS IN REVERSE, correct?
If that's the case, then it sounds as if either a fuse has blown or, simply a connection has gone bad that, triggers the monitor and camera for IGNITION ON phase of the wiring. Mine is the Sony system and that's how it works but, again, I'm not sure yours is wired the exact same. I would suppose it's very close to how mine works.
Yes, there should also be multiple inputs on the back side of the monitor. Those are for alternate inputs like side view cameras and more. When mine was brand new, the coach came with an "Alpine" GPS system that was wired into one of those other ports. It was broke and out of service by the time we acquired the coach.
Anyway, do check for a possible fuse or, loose connection.
Scott
38,705 PostsLatest Activity: Jan 22, 2025
