Sparkie616's avatar
Sparkie616
Recall Letter for Workhorse Chassis
I'm in the process of importing a '04 Fleetwood Fiesta into Canada. It's on a Workhorse chassis. According to RIV I need to obtain recall clearance letters for both the body (Fleetwood) and the chassis (Workhorse). I have contact info for Fleetwood, but I'm not sure who to contact about the chassis. I'm assuming WH was owned by GM at the time. Any suggestions???
  • You'll need to go to www.workhorse.com, create an account and register your new coach with Workhorse. Once that is complete go to this site http://workhorse.com/Default.aspx?tabid=560 for Canadian recall info in the right side of the page. It the required doc is not there, contact Workhorse directly via this number (877) 246-7731
  • rvten wrote:
    Workhorse was not owned by GM.
    It was a division that split off from GM, but that happened well before 2004.
  • Go here and register the motor home. Workhorse registration
    This will then tell you what recalls are applicable for your coach and when/if they have been taken care of.
    All you need is the VIN to register and a little bit of your personal info.
