- frankdampExplorerUnderneath, your RV is a TRUCK! Commercial box truck owners/drivers sure don't spend the extra for Super.
- wa8yxmExplorer IIINow there are exceptions and I'll cover one or two of 'em but every expert, EVERY EXPERT I have heard from (And there have been a lot of them) say the same thing READ THE MANUAL.. Most modern engines are designed to run on REGULAR Gasoline and if this is the case paying for Mid Range or Premium is a waste of money.
HOWEVER.... Exception one.. At very high altitudes they lower the octane of Regular.. When I got gas at altitude the engine did not run well.. Switching to Mid Grade to maintain the minimum octane rating would likely have been a good idea and next time I'm in the mountains,, that is what I will do.
Exception two: This was a car, a 1997 with a carburetor not a modern computer controlled EFI job Turns out the factory carb was faulty.
I keep MPG records. Every fill up (Which reminds me I need to do a calc or 2) And that car got much better MPG on Mid-range... ENough to make it the best bargain.. It also did better after waxing, way better.
on the motor home.. Waxing.. Same result. Better MPG.. Way better. - jerseyjimExplorerMotor calls for "regular" (87 octane) that's all it needs. Getting "premium" (92 octane), IMO, you're just throwing money away. As far as pinging goes,,,the computer takes care of that in a nano-second...by retarding the timing until it no longer "senses" a problem.
- koda55ExplorerIn our 35ft v10 with the 310 hp we got the same mileage with premium grade as we did with the regular grade gas.
- rgatijnet1Explorer IIIUse what the manufacturers recommend. If they say 87 octane, then use it. As far as comparing mileage of different brands, those figures can vary even if you use the same brand of fuel.
If you look at the pump next time you buy gas, read what the "ethanol" sticker says. It usually says something like "UP TO 10% ethanol. This means that it may have 2%, 5%, 8% or 10% ethanol. The actual amount will vary and the more ethanol that is in that particular station's tank on that day the lower your mileage will be. Come back next week to the same station and the amount of ethanol may be less, who knows? - AZAmmochiefExplorerIf you Google this subject, there are no less than 15 web sites which have written about this subject. Every one of them come to the same conclusion, stay with the gas your vehicle is designed for. Using premium gas makes no difference, except it may cost, maybe, a dime more per gallon.
- spadoctorExplorer IIIn most US fuel terminals all gasoline starts the same. If it will be Shell it gets the Shell addatives....if Mobil/Exxon it gets their package etc. The V10 was designed to use 87 octane....use it as you will not increase mileage using premium.
- allenmExplorerI tracked mileage on my 27' Class C with a Ford V10 on various brands of gasoline for several years. I consistently got better mileage using top brand names like Shell, Sunoco and Exon. I could never get the same mileage using discount brands like Murphy, etc. I will admit if you take the price difference into account with the mileage, it might work out about the same overall cost.
My Ford V10 never pinged on anything, but octane doesn't seem to affect mileage.
So, what's different about discount brands. Not sure - maybe the fuel is older? I know gasoline has a short life, as far as top efficiency. Some say there's no difference and even come out of the same delivery truck - yeah, right. All I know is my tracking showed there is a definite difference.
Or maybe the discount brands are more likely to have ethanol. Ethanol will definitely lower mileage. Just about any brand, even top brands, come with and without ethanol. It's up to the distributor/station which to sell. Most states require a sticker on the pump, but they have a way of disappearing.
Best bet for top mileage is to buy top name brands without ethanol - if you can find it or even care anymore... - free_radicalExplorerI only use what truck manual recomends..87 regular in my case,,fuel up at PetroCanada stations as much as possible as it contains some kind of Tactrol(sp)
Aditive that cleans the engine,,have been very satisfied with this for many years.. - Kayteg1Explorer IIThe latest generation of digitally controlled engines can better compensate for fuel quality, but years ago I drove 1984 Volvo, what was 1st generation of digital engine management.
The engine was design for regural, but with 112HP it was struggling on long grades we have in CA.
So for annual trips to Las Vegas I was fueling with Premium.
Thanks to that instead of redlining on lower gear, the engine would pull the grades on overdrive.
I did not do it for fuel saving, but for time saving, but strongly believe that avoiding downshifting saved fuel as well.
Maybe not to degree to make it worth spending extra money, but to consider.
About Motorhome Group
38,782 PostsLatest Activity: Sep 10, 2026
