Whaler's avatar
Whaler
Remote gennie switch failure
I have a Generac NPG 66 generator. The remote switch will do a start up but fails to shut down generator. The switch located on the gennie performs normally (on/off), it produces power with no issues. Tests shows remote switch to be good. It is a rocker style with on/ neutral/off with a run indicator light located next to it and a lead to the hour meter. Leads to it indicate continuity as far as I can check. This is beyond my skill set. Any suggestions or similar experience would be appreciated.
  • You're welcome. Those plugs, at least on mine, are exposed to harsh conditions from road spray, crud and corruption. It's amazing they hold up as well as they do.
  • You nailed it zig. Corrosion on connecter at back side. There was not enough to hardly see but it was enough to interrupt the connection. Thanks
  • Gjac's avatar
    Gjac
    Do both your remote switches act the same way or just the one on the dash?
  • Check the wire harness and plug at the genny for a broken wire or corroded plug. I've had similar problem, except it wouldn't start, but would stop the genny.
