Mr_Mark1
Feb 05, 2017Explorer
Toddupton wrote:
Also not sure about adding more water capacity than holding tank capacity. If you have 100 gallons of water but only 50 gallons of storage in the gray then what can you do with the other 50 gallons? You would have to dump it to keep using your other 50 or use the outside shower a lot.
^^^^^^ this makes so much sense to me. Keeping the 'fresh' and 'holding' tanks near the same size would allow for boondocking off the grid longer and would match the fresh tank (mostly).
Having three times the fresh water capacity vs. holding tank capacity would make you have to dump the 'holding tank' more often.
Safe travels,
MM.
38,705 PostsLatest Activity: Jan 24, 2025
