Ivylog
Aug 07, 2014Explorer III
Replacing fan motor in roof AC
Several years ago the fan started to slow down after several hour of use. Tried oiling the bushings which seemed to help but recently it's gotten so bad that after 15 minutes the motor slows down and even stops. Decide to remove the motor but it's a heck of a project because of all the sheet metal that was not designed to be removed. Even though the motor shaft was centered in a hole in the sheet metal, the fan was very close to the bottom so I decided to raise up that end of the motor. Put 3/16th of spacers under the motor mount and now the motor turns freely. Apparently over time and bouncing down the road the bottom pan of the AC has bent upward and the fan was rubbing on it. I now have a well oiled fan motor and fortunately I had not bought the replacement motor I'd found on Ebay.
