mlw5000's avatar
mlw5000
Reset the circuit breaker
I tripped the circuit breaker and the AC won't work, I think. Ifound the distribution box but don't know how to reset it. I have a National Seabreeze, 1995,model 131, Class A It happened when I had it plugged in to my homes power supply, which is not 30 amp. The picture in the owners manual does not look like my distribution box. Can someone help.
  • mlw5000 wrote:
    Do homes have 20 amp breakers?
    Many of mine are.
  • Thank you for your responses. The breaker is in the RV. I'm just guessing that that's what happened. All I know is the AC doesn't work now.
  • Is it the breaker in the house or RV? RV breakers when tripped need to be turned off when tripped then back on to reset them.
    To run the AC from a house outlet, it needs to be a 20 amp breaker with nothing else running off it. Also your power cord has to be able to handle the 20 amps.
  • I'd take a look at the circuit breaker in your house instead of the camper...
