Back in 2014 our fridge failed for the second time. We replaced the cooling unit with the Amish one the first time to no avail. After this failure, I was done, so I switched to residential. Going on five years now and I would not buy another coach without a residential. We purchased the Samsung197 because it fit almost exactly in the same space our 1200 came out of. We took the old fridge out thru the emergency window and brought the new one in the same way using a forklift. Very easy to do. We run the fridge off the inverter while traveling and have run it all night off the inverter with zero problems. Below is a link to our install. I accomplished it myself over a two day period in a campground in Gulf Shores Alabama....Good luck. With a residential you'll be pleasantly surprised....Dennis
Residential Fridge Install
