the_silverback
Dec 27, 2015Explorer
roof air failures
In just the last 3 months 7 of my friends have their roof air units fail. 4 of the RV's were new. Has there been a design change? Have any of you seen a similar situation? Seems weird to me.
DSDP Don wrote:
I don't understand.....Dometic had a bad batch of A/C units where the boards were not soldered correctly.....they replaced them and the problem was resolved, yet it somehow becomes a platform for people to bash new coaches and justify keeping their old ones. Does that mean the people with older coaches NEVER had anything go wrong or will in the future due to age?
bullydogs1 wrote:that was when they switched to the "quiet" blades. I had a fan crack made a loud noise and I was able to shut the unit down. When I replaced the fan I found two of the three isolator mounting screws were missing . Needless to say I removed the screws from the other 2 a/c units and put locktight on them. Entegra sent me three fans when one cracked so I replaced all three
Some of the Coleman Mach units were using plastic fans and they crack and throw the parts inside the cover itself taking out the whole unit with them...While Entegra Coach has been plagued with these, they do have a revised fan available....
the silverback wrote:
Donfromp, In answer to your questions, Both AC's were Dometic. One of the RV;s, a park model was purchased 2 or 3 weeks ago. The second RV, a travel trailer, was purchased 2 months ago.
