Sort By
- allbrandautoExplorermy mattress is a standard queen 80 by 60 has anybody bought one from brooklyn mattress
- LouLawrenceExplorerIf you are in TX, Texas Mattress Makers will make any size and shape mattress you like. Denver Mattress will do the same, I understand. We measured and drew the curves at the end of ours and Texas Mattress had ours done in about 10 days.
- rgatijnet1Explorer IIIAny upholstery shop can make you a mattress according to your specs. You can pick the type of foam that you want, cover material, layers of foam, etc. We had them put a zipper on the cover so that it could be washed occasionally. The cost will be about 1/2 of what a mattress specialty store will charge you.
- Yankee_ClipperExplorerThe Denver mattress in our Winnie hit the dumpster two days after we bought our ring in 2018. We went on line and bought a 10" hybrid RV queen mattress in a box and a 2" gel foam topper. Wow, what a difference. We also bought deep-pocket sheet sets (2). We bought online from Wayfair.
- RedRollingRoadbExplorerhttps://www.mattressinsider.com/
- jdc1Explorer II
- Beverley_KenExplorerIf it is a full size queen (60x80) that's easy. Any place that sells mattresses, does NOT have to say RV. If it's a short queen (60x75), you may have to shop around a bit more, maybe a mattress specialty shop.
More importantly is getting one that your body (and DW) are comfortable with.
Personally I like a very firm mattress, but after back surgery, my back prefers something a bit softer and conforming. I think that the 3 inch memory foam topper is for me. Checking out at home before duplicating in MH.
Ken - 2oldmanExplorer II3" memory foam over 4"foam, cut to size
About Motorhome Group
38,718 PostsLatest Activity: May 03, 2025
