Yosemite Sam1 wrote:
pnichols wrote:
pnichols wrote:
m37charlie wrote:
Winter camping: ....
.....Spending time outdoors in near cryogenic temperatures especially when solar insolation is minimal (like around the solstice) isn’t fun except as a novelty. So even if one’s RV can theoretically “take it”, are you going to spend all the long nights inside and venture outdoors for 2 hours a day?
I realize camping in ~+20F with much longer lower 48 days is much different.
But there are very good reasons why lots of Canadians migrate themselves and their (somewhat cold capable) RVs to Mexico or the USA southern states in the winter if they are full timers.
Sorry for the lengthy post but the stories are true and the calculations correct.
Dr. Aarons,
A great writeup on your adventures in the extreme cold (that I referenced in part above)!!
And now ... going off topic regarding another ultimate RV'ing challenge ... in which neither more clothes nor nudity are a solution. What would you recommend for drycamping in above 100 degree F outside air temperatures?
The reason I ask is this: The DW and myself enjoy rockhounding using our small Class C motorhome as a base ... even if it takes us out into the U.S. version of The Far Side of Beyond. The good thing about doing this in the summer is the complete lack of any other people around. The bad thing about doing this is it's in the summer. Our worst case was way out there in the Texas Panhandle during August. We had to use both the rooftop A/C and built-in RV generator, plus the cab A/C with the engine idling - to keep from melting away after a few minutes outside. The complete serenity while walking around outside in lite clothing under umbrellas and cloudless blue skies was beyond priceless ... just us, the RV, and the Road Runners scampering about. ;)
Here's my answer to my own question above on high temperature boondock camping:
1. Inside the coach - use a high power 12V fan powered from the coach batteries for directed air right on you, and/or use the rooftop vent fan powered from the coach batteries set on high for circulation.
2. Inside the coach - use the rooftop A/C and built-in generator, while pressurizing the coach interior to keep all generator fumes from entering.
3. Outside the coach - sit under the awning and use a high power 12V fan on an extension cord powered from the coach batteries for directed air aimed right at you while sitting in a lounge chair. NEVER walk around outside not under the awning in high sun situations without being under a light colored umbrella.
For us when we're camping in the heat for a reason, we cannot move to another location to escape the heat. I'm curious as to how others deal with high temperature camping - without moving the RV out of the heat.
We simply went home.
I have to put ice cubes inside a towels on top of my head and back of the neck to prevent me from passing out or having a heat stroke, lol.
I've posted this before, but here it is again for what it's worth: We had a similar near heat stroke experience once with our RV when we couldn't go home. We were in the Texas Panhandle rockhounding in August in most likely triple digit outside air temperatures.
When we really got heated up and hungry in the middle of the day, we went back to the RV and fired up both the coach air conditioner/generator and the cab air conditioner/V10 engine. Triple digit outside temps were no match for double A/C's in our small Class C. We got comfortable very quickly and enjoyed a good lunch out in the middle of nowhere.
Needless to say we had the whole area to ourselves and our rig took care of us . :)
