DutchmenSport wrote:
I'm able to see the image now. I can't believe Thor installed it that way. It had to be installed by second-party, not the manufacturer. If using bolts, the bolts should have gone through the frame (Horizontal-sideways), not on the bottom, (up and down vertical). No, this is after market, never intended by the manufacture to tow anything. Frame is too light. You can see that, especially compared to the hitch metal. Also, hitch looks much newer than the frame of the MH. In my opinion this is a result of overloading. Here again, is the brother the first and original owner?
Wrong my Dutchman friend... Check their specs site...
Rear HitchRear Hitch TypeReceiverTongue Weight 500 lbs. Tongue Weight (kgs)226.8
Towing Capacity 5,000 lbs.
Their specs/their equipment
