โFeb-23-2018 04:03 PM
โMar-09-2018 03:02 PM
โMar-08-2018 06:42 AM
RLS7201 wrote:
The RV industry has punished us with Dicor calk for years. It was/is never a permanent solution. As previously noted, over time it needs to be removed and reapplied, due to cracking and unbonding.
A more permanent solution is Sikaflex 715 rubber roof calking.
Richard
โMar-07-2018 05:01 PM
โMar-07-2018 04:51 PM
โFeb-28-2018 07:06 AM
โFeb-27-2018 06:36 PM
โFeb-25-2018 08:31 AM
โFeb-25-2018 04:33 AM
โFeb-25-2018 04:02 AM
โFeb-24-2018 05:08 PM
โFeb-24-2018 01:59 PM
โFeb-24-2018 07:54 AM
โFeb-23-2018 09:00 PM
dlnc wrote:
We have a diesel pusher with full body and need to do some maintenance....with that I have a few questions;
For the front and rear caps, should I peel off the old tape first or can I just tape over the current tape joint.
Since my coach has full body paint, what is the best sealant to use on the sides where the old sealant is cracking. I cannot use white with the body paint. I am also concerned with the sealant sagging since it will be applied to the exterior vertical surfaces.
Im thinking I may need to find some color sealant to blend in with the body paint.
โFeb-23-2018 05:50 PM
