Brand new RV’er when i arrive at a site with a Class A MH Do I 1 level the rig with the stabilizers then deploy the slide out 2 deploy the slide out then level the rig with the stabilizers ...
it comes down to reading YOUR owner manual first before doing anything. some manufacturers say slides first then level and some are just the opposite. so if you want the correct procedure, read the manual first, that would be the correct answer
