aw2055989
Jan 22, 2014Explorer
Sewer Hose recommendation to fit storage tube
I have a 2009 Coachmen Mirada 33' Class A unit. It has a swing out sewer hose storage tube under it. I'm sure the purpose is to allow you to have your hose hooked up at the campsite while being able to keep the sewer/water access door closed. Problem is, if you buy a nice rhino hose (or whatever brand) with fittings already attached, then you can't slide the hose in the storage tube since the fittings are too big. I'm looking for recommendations as to what hose/fittings I should be looking for. I'm guessing I have to find something along the lines of a hose with no pre-attached ends and then buy ends separate? I know, sounds like a dumb question.....but looking for the voice of experience.
