I just purchased this for our MH as our dump connection is literally inches from the ground with the hoses attached. It's been a real pain trying to dump at times as I found myself walking the sewage ...
I have used the sewer solution for nearly nine years. The hoses stay secure without the use of clamps. If you attach the extension, you will notice that they slide together while you are twisting in one direction, but will not slide together if you are twisting in the opposite direction. Once you have them joined they stay that way until you twist in the right direction while separating them. I have never experienced one coming apart. Much better than the stinky slinky in my opinion.
