Aug-06-2013 06:11 AM
Sep-06-2013 07:47 PM
Sep-04-2013 12:38 PM
Sep-04-2013 12:19 PM
Roadtrekker2 wrote:
I received my new Sewer Solution kit and was looking in stores yesterday for a second backflow preventer like the one that came with my SS. I couldn't find one. I've been searching the internet for the person who used two as insurance against preventing contamination, but once again could not find that person. Do any of you know where I can purchase another connection like this to prevent contaminating my fresh water at my house if I need to dump tanks at home (in the basement.) Should I contact a plumber? Should I be worried?
I am going out this weekend to try the SS. Keep your fingers crossed for me! 🙂 (I'll be using a state park dump which has a NON-POTABLE water supply with a threaded end on the hose.)
Thanks.
Sep-04-2013 10:46 AM
Sep-04-2013 10:38 AM
Thanks.
Sep-04-2013 09:56 AM
Aug-17-2013 08:41 AM
Roadtrekker2 wrote:
I have purchased a Sewer Solution, but am worrying a bit about contaminating my fresh water supply when using it as suggested by some reviewers. Could someone tell me how this would happen when they are two completely different systems on a Roadtrek? How could back flushing to clean out the holding tanks contaminate my fresh water? (I would not ever consider using the potable water supply for any of this.)
Thanks a lot.
Aug-17-2013 07:57 AM
Aug-17-2013 03:53 AM
Fastpaddler wrote:
I returned from Gabriola Island after a few days dry camping. I tried a procedure to help clear out the black tank and get indicator to EMPTY. I ran the PW up onto two interlocking leveler block on the RIGHT SIDE, front and rear. I used my spray wand connected to the special hose I use for cleanouts. Worked great.First time I have gotten an ''empty' indicator on Black tank monitor. What are the "outside tank sensors'", Bumpyroad?
Aug-16-2013 10:27 PM
Aug-13-2013 03:55 AM
Aug-13-2013 01:27 AM
Fastpaddler wrote:
I do what mlts22 does:With both black and grey closed, I first dump the black tank then, with it's valve open, I dump the grey which also flushes the black tank. I do not have a macerator. I usually run a gallon or so water from the shower head unit into the toilet which helps clear the black tank. If there is a better way I need to know about it. My only problem is the black indicator level on the panel often shows the black is one third full when it is empty. I replaced the black sensor but still is quirky.
AL
Aug-12-2013 10:14 PM
Aug-09-2013 09:48 AM
