brodon's avatar
brodon
shower fixture
I need to replace our single lever shower fixture. Pull panel to see fixture. Looks like a regular set up. question is will a regular home fixture work?
  • THANKS FOR THE REPLIES...HAVE DONE PLUMPING BEFORE...SEEMS AN EASY REPLACEMENT WITH HOUSEHOLD FIXTURE...JUST NEED TO GET RIGHT FIXING FROM RV PIPE TO NEW FIXTURE...
  • Most parts dealing with water problems, I found Lowes to be a big help! In AZ. they even ordered parts for me that they didn't have in stock. They have great customer service!
  • Changed mine out but went to a plumbing supply store used by contractors to get a model close to the original. The new one sticks out into the shower about an inch farther though. The main problem I had was trying to use the old fittings (don't even try) save yourself some headaches. The new pex fittings and pipe worked perfectly. I did have to open up areas above and below the shower valve. Went to Tap Plastic for panels to cover the openings. It worked well and looks nice too.
  • How about a picture?
    I replaced very cheap shower/vanity fixture in my camper with thermostatic household fixture and love the looks, like the convenience and love water saving.
  • pull it and go to your plumbing supply, they should be able to find one to fit. I have replace all of mine except the shower with off the shelf items.
