bamaboy473
Jun 08, 2014Explorer
eheading wrote:
One easy way to check out the voltage issue is just keep the engine on when working the slides. If you still have a problem, then it probably isn't a voltage issue.
Ed
Thanks, Ed. No, it isn't a low-voltage issue because I'm connected to shore power here at the house, so batteries are all topped off.
Given that Equalizer hydraulics are supposed to be self-adjusting for pressure, I'm beginning to wonder whether there's a pressure valve of some sort that's restricting flow to one of the cylinders?
Of course, that likely has nothing to do with the motor dying, or could it?
