want-a-be wrote:
dougrainer wrote:
I did not catch you said living room slide. Is this slide a HWH Hydraulic slide? Most Phaetons, the front drivers Living room slide is electric and the Pass side is hydraulic. But, they do have Hydraulic on the drivers side. Which slide do you have? Electric or Hydraulic? It makes a difference. If Hydraulic, that nylon is from HWH, if Electric, then Tiffin is the supplier. Doug
The two front slides are both hydraulic.
Then the part is HWH. The Nylon glides are installed inside the tube rails and keep the steel tubes from having metal on metal contac. The inner tube rides on that nylon glide. Doug
