markop wrote:
I recently acquired a new 2013 Winnebago/Itasca Sunova and am experiencing loud squeaking and rubbing noises from the driver side slideout while underway. The noise is directly behind the driver and seems to happen at all speeds. The slideout rubber gasket seems properly compressed with the slide in but not sure if it is an adjustment problem or something else. Thought I'd check the forum prior to asking the dealer to trouble shoot it.
Our roadside slide started doing this after about three years. In our case the noise is coming from contact with the vinyl flooring on the rear end of the slide. I simply slide a piece of cardboard between the floor and slide and it goes away.
