Maybe you should have bought a pop up. Lol
I'm with this guy Jack at the campground and just want to elaborate on the problem and what troubleshooting we have already done in his unit.
When attempting to open or close glides or leveling jacks I measured voltage across the relay (which you can hear clicking). There is 12 volts to the coil and the contacts close so there is also 12v to the pump. Pump does not turn on though. We checked all the grounds in the area to the ground stud ad all appear to be intact. I do not see where the pump ground is attach so I'm assuming its done internal to the pump. Our initial thoughts are since the pump is getting voltage but not turning on it must be a bad pump, but not knowing the electrical circuit maybe there is another contact in the ground path that is preventing the pump from turning on. One more bit of information is this appears to be an intermittent problem.
Any help would be appreciated.
