Alberta_John's avatar
Alberta_John
Slides not working
I have a 2008 hurricane 33T. After a long hot day on the road the slides will not work until the relay cools down and is reset. This reset is in the fuse box on the front of the engine. Anyone having this problem? Will a new relay help? Thanks
  • I'm thinking what you're calling a relay is an auto reset circuit breaker. It's probably just doing it's job of opening the circuit when it's overloaded. If it were bad it would either open and not reset or not open at all letting the circuit burn up.
