slow start on 89 Southwind
MandJ_01
When ever I start my rv it seem to be slow (starter) but it still starts fine and runs well. Its
Like a 3-5 sec delay before starting. Don't know why the battery is new and fully charged it is the right cranking amps. Is this normal Help
11 REPLIES 11
MandJ_01
OK thanks guys I will try them all
Matt_Colie
What you are describing is typical of a bad battery connection. It will start to conduct better when it heats up. This condition does not exist long before it fails.
Do this....
Next time you try to start it, as soon as it cranks, let go of the key and feel the battery and starter connections including the grounds. One may be warm. If you find it - Fix it.
Matt
Matt & Mary Colie
A sailor, his bride and their black dogs (one dear dog is waiting for us at the bridge) going to see some dry places that have Geocaches in a coach made the year we married.
imadtchmn
might check the battery connections at the starter also. Have seen them loosen up and cause the condition you described.
1998 Chevy 6.5 TB Dually maxed out for power
2004 Dutchmen Classic 33RLK
DH George
DW Sherry
Dog Lady
MandJ_01
Yes Turbo and thanks I will
Try that
turbojimmy
So to be clear - you turn the key to start, but nothing happens for 3-5 seconds before it will actually crank?
My guess would be the starter solenoid. On the Fords I *think* it's separate from the starter motor itself so it should be easy to replace once you locate it (on GMs it's mounted to the starter).
1984 Allegro M-31 (Dead Metal)
MandJ_01
tommykelly wrote:
I need a oil filter for my truck...
what kind of truck.....
it is a blue truck.....
Tommykelly I don't know what your comment means but if your referring to my post it state in the title year and model it is a general question meaning with any Rv if anyone had such a issue. thanks
MandJ_01
1989 32' Fleetwood Southwind Ford 460 77k miles
tommykelly
crasster
I've seen starter solenoids be slow to engage. Put a meter on it and have somebody turn the key.
4 whopping cylinders on Toyota RV's. Talk about great getting good MPG. Also I have a very light foot on the pedal. I followed some MPG advice on Livingpress.com and I now get 22 MPG! Not bad for a home on wheels.
Johno02
duplicate, please delete
Noel and Betty Johnson (and Harry)
2005 GulfStream Ultra Supreme, 1 Old grouch, 1 wonderful wife, and two silly poodles.
Johno02
What type and brand, model year, and engine type and size??
