SOLVED & updated: Any mechanical/electrical genius out there
Tinstar
This is a 1994 Tiffin Allegro Bus 34 foot diesel pusher.
Here's my problem: I am having to turn the key to the start position 10 or 12 times to get the engine to crank or if I hold the key in the start position for 6 or 8 seconds the starter will finally engage. I have already replaced the ignition switch on the steering column (actuated by the key) so the starter switch is good and the symptoms are the same with the old or new switch. The starter solenoid is good, the starter is good and the starter relay is good. I've checked all of the above items using the accepted process of elimination with a 12 volt test light. The problem seems to be the start wire from the starter switch is not making good contact somewhere between the starter switch on the steering column and the starter relay in the back engine compartment.
I've attached a photograph of my fuse panel. I am wonder if the yellow fuse in the panel labeled ign (ignition) might be causing the no crank problem. A couple the fuse slots have melted somewhat and/or has broken pins. I've already found and repaired the cause of the melting. That yellow 20 amp ignition fuse slot does have a broken fuse pin on the left side (this is on the the hard wired part where you insert the fuse and not the fuse itself). The fuse is making contact on that one side fuse legs but it's probably not making ideal contact. Anyone know if that fuse might be the cause of the no crank problem.
I have checked the start wire from the ignition to the starter relay by tracing everything accessible. My goodness what a cluster of wires. I have been unable to locate a problem in that wire anywhere that I've been able to find. Like I said, after holding the switch in the start position or repeatedly hitting the start several times, the engine will crank and run fine. There is no problem with the engine performance after it starts. I know I can wire a momentary switch at the drivers position to the starter relay but I would rather fix it the right way.
I'm open for any suggestions and thanks for any input.
:CNever pass up a chance to go somewhere:C
15 REPLIES 15
YC_1
Could you tell us more about the Fox and Hound tester?
fox and hound, one example
Connect to the wire you need to trace. It sends a signal down the wire. The other part picks up the signal inductively versus having to penetrate a wire. So you can follow a bundle of wires or bypass whole sections to find the other end.
H/R Endeavor 2008
Ford F150 toad >Full Timers
Certified Senior Electronic Technician, Telecommunications Engineer, Telecommunications repair Service Center Owner, Original owner HR 2008
Tinstar
chuckftboy wrote:
I had the same problem 2 years ago. Good voltage, good grounds even went as far as to replace the starter. The problem was a plate inside the battery seperating under load. Sometimes it would make sometimes not. Drove me crazy for 2 days while on the road until I installed a new battery.
When I turned in the old battery for a core credit, it still showed 12.7 volts. Never tried my battery boost because my battery never even dimmed the lights and never showed low voltage.
I did the exact same thing 4 or 5 years ago. I spent 2 days messing with stuff. People were telling me it was the battery but I wasn't listening. Mine was showing 13.6 volts after charge but the plates were shorted and wouldn't turn the starter.
I put in a new battery this time but the old one wasn't holding a good charge anyway.
chuckftboy
2019 Horizon 42Q Maxum Chassis w/tag
Cummins L-9 450 HP / Allison 3000
2006 Jeep TJ and 2011 Chevy Traverse Tows
Tinstar
For those of you that suggested the a relay or the lazy relay, you win the cupie doll.
Of course I checked the relays in the fuse box but I talked to a diesel mechanic and he said since all other items were checked, there is bound to be another relay somewhere in line that is causing the no crank. I found another one in the engine compartment that was just hanging by it's wiring harness. Pulled it and put in a spare I had and viola, the engine cranks first time, every time.
Why a manufacture wouldn't put the relays with the others in the fuse panel is beyond me. In fact I found another one under the dash dangling from its harness. I had to stand on my head and turn my eyes inside-out and backward to locate it. There's no telling what it goes to.
Bottom line; I spent 3 days underneath, in the engine compartment and under the dash to fix something that only took 15 seconds to fix. At least I know more about the wiring and I'm a happy camper again.
bukzin
YC 1 wrote:
No reason to run a separate start button. Just find the wire that is supposed to start the thing, cut and splice a new wire where you are getting good voltage immediately and run it to the starter terminal. Of course this is not the heavy starter cable I am referring to. The solenoid that kicks in and sends the heavy current to the starter of course.
I seem to have an open wire on my RV as of a couple of days ago. Chasing it is all but impossible without my Fox and Hound tracing device.
Your description sure sounds like a lazy relay/poor contact.
If your signal passes through one of those relays shown in your picture try removing them one at a time to see if it PREvents the engine from turning over. If you find one that does, swap it with one of the others that has the same part number.
Could tell us more about the Fox and Hound tester?
Maybe a photo and supplier?
Thx
2006 Monaco Diplomat 41'
Cummins 400hp ISL CM850
YC_1
H/R Endeavor 2008
Tinstar
I'll check voltages at all the post but from checking yesterday, there will be NO voltage at the S (start) terminal on the start solenoid until after 8 or10 seconds. I crawled from front to back underneath it yesterday and there is no damage to the start wire anywhere along the way. I repaired the damaged 20amp fuse holder and replaced the ignition relay. I cleaned the ground wire connections and the solenoid works as it should or at least it does when 12volts finally reaches the S terminal,,, which takes 10 - 12 seconds. I read yesterday that the MD3060 Allison does not have a neutral control switch.
If the voltages read OK (and I think they will) at the terminals, does anyone else have any suggestions. My only alternative is to wire a push button starter. I would just run a new wire to the solenoid, turn my ignition to run and then push an aftermarket button.
Geocritter
I was having starter problems with my 1994 460 V8 powered Holiday Rambler. The starter barely cranked. I had the starter rebuilt and installed a new 750amp battery and new battery cables but sill no joy, in frustration I purchased a new starter assuming the rebuild was bad, still wouldn't crank worth a flip. I finally went out and purchased a dedicated ground cable for $8 and bolted one end to the frame and the other end to one of the bolts that attached the starter. FINALLY! Problem solved.
YC_1
I too would park the test light at this time. You need solid voltage information now. Could easily be a ground. Start right at your starter solenoid. If you have a smaller relay driving the starter solenoid you need to measure voltage on all four terminals or the metal housing if there isn't four terminals. Drag your shoreline cord around and use the ground lead so you will have the same reference while taking any measurements.
One trick on a sloppy fuse holder is to twist the fuse legs a bit.
With all of this my question is do you hear any clunking near the engine area every time you turn the key or only when it decides to engage? If you hear any solenoids clunking and no engine cranking that is where I would start with voltage measurements.
H/R Endeavor 2008
darsben
WyoTraveler wrote:
JMHO. I would temporarily by pass the fuse with a jumper and fuse. If it solves the problem most likely the fuse contacts. If not, I would temporarily run a complete wire from ignition. I'm sure you realize if you took it to an electrical repair shop they would most likely just run a new wire from the switch to the solenoid with a new fuse in the line. I had a similar problem with my previous PU. Mice had chewed half way through some of the wires. Easier to replace bad wire than an entire cable.
X2
Cheap test no real money or time invested. This is a good place to start.
Even if it is not the problem I would run a new wire with an inline fuse. It is a future problem just waiting to bite you on the posterior at an inopportune moment
Traveling with my best friend my wife!
midnightsadie
sounds like burnt contacts ,in a start relay.
Bikeboy57
Most of us, including me, trace down the hot side of a 12V DC system when troubleshooting. You will need to confirm good grounds on all the relays and solenoids.
You can't do that with a test light. Invest in a voltmeter if you don't have one.
Check ALL Grounds.
Richard and Rhonda
1999 Newell
Subaru Outback toad
rcmiller32
I would look for a large HD starter solenoid between the chassis batteries and the main starter solenoid. Most times this was closer to the batteries and then a heavy cable would run to the starter solenoid. Also check all the battery and solenoid connections closely for corrosion and dirt. Last I would check out for a possible defective neutral safety start switch or relay.
2014 Coachmen Pursuit 31BDP
2016 Ford C-Max Energi
Member FROG, FMCA, Life Member Good Sam Club, Member Coachmen Owners Association
Victory402
I would like to think there is a relay that brings in your starter solenoid. Might be bad?
