โJan-26-2021 03:50 AM
โFeb-05-2021 04:12 PM
pnichols wrote:
For you folks who want to start carrying a spare for their Class C, but also want to maybe carry along something else that requires use of the rear hitch ... you might want to consider a front hitch, in addition to the one in the back.
My preference would be to add a front hitch so as to either A) not have to carry a heavy thing that mounts in the back hitch or, B) not have to use a long hitch extension in the back that sticks out quite a bit for the carrying of two things. For a Class C, too much weight way at the back hanging off the hitch can negatively affect steering.
โFeb-05-2021 03:35 PM
โFeb-05-2021 03:26 PM
โFeb-05-2021 10:31 AM
โFeb-04-2021 06:52 PM
TxGearhead wrote:
Coachman no spare? BS. Assuming Coachman was gracious enough to install a receiver hitch, use that for a spare wheel and tire. Like this:
https://www.amazon.com/CURT-31006-Hitch-Mounted-Spare-Mount/dp/B0009YIE1O
f you're using the receiver for something else (bikes?) use this:
https://www.amazon.com/CURT-45792-Receiver-Trailer-2-Inch/dp/B00371VLAC/ref=asc_df_B00371VLAC/?tag=hyprod-20&linkCode=df0&hvadid=241915008172&hvpos=&hvnetw=g&hvrand=4505672379815143385&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9027838&hvtargid=pla-571952257097&psc=1
โFeb-04-2021 06:46 PM
Bordercollie wrote:
I am 82 and like a lot of older RV'ers, I have problems doing a lot of things because of leg problems. Assuming that most RV'ers are physically capable of unbolting, jacking, breaking loose, removing, carrying a dual tire and wheel, and installing a spare (safely), DIY style, is not realistic.
โFeb-04-2021 03:07 PM
โFeb-04-2021 10:55 AM
โFeb-02-2021 11:14 AM
vjswhippet wrote:First of all, I would likely have flipped the dealer the bird for making such an absurd comment. How does he have any idea what you are capable of doing? Second, a spare on a class C is indeed relatively easy to change; no different than your average dually pickup, ALL of which come with a spare and the tools to change it. Finally, since RA is not always available (no cell service, out in the boonies, etc), and many WON'T go off the pavement, and you are also at the mercy of pricing/availability for a compatible tire, actually having a spare (mounted) and the tools to change it is simply the prudent way to go, whether you can change it yourself or not.
My new Class C does not have a spare tire. When I asked the dealership about it, they told me I wouldn't be able to change it anyway. Yes, I know that but it doesn't make sense to me NOT to have one for Roadside Assistance to change it for me. Or do they have tires in stock to bring with them ?
โJan-28-2021 07:17 PM
โJan-27-2021 08:00 PM
โJan-27-2021 12:12 PM
mgirardo wrote:
I was chatting with a fellow camper once that told me he had a spare for his Class A, but it wasn't mounted and with his road side assistance either CoachNet or GoodSam, I can't remember which, he had to pay $100 to remove the flat from the rim and put the spare on.
So check with what your Roadside Assistance Program offers.
-Michael
โJan-27-2021 12:10 PM
โJan-27-2021 12:05 PM
Seattle Steve wrote:
I'm in the "I don't care about the spare" category. The last flat I had was as a teenager in 1972 on a motorcycle I bought from a friend for $100. But I do always replace my tires early and check the pressure and tire wear regularly.
If you're talking about the motorhome in your signature, the F-450 is very common and, should you need a replacement tire, will be easy to find. If you buy and carry a spare you have to remember to replace it every 7 years. If you're constantly replacing unused tires because of their age, that's wasted money. If I happen to need a tire on the road, even if they charge me double the going rate, I'm still way ahead on money.
So, no spare (or roadside assistance plan, or extended warranty) for me. I self-insure on everything, and over the years I am way ahead financially. On the rare occasion I need something, I rely on a credit card and the promise of a really good tip to the person taking care of me.
