- Empty_Nest__SooExplorerWest Virginia requires a CDL to drive a truck at or above 26K pounds GVWR.
West Virginia does not require a special license to drive a personal RV or a rented moving van used for your personal belongings, regardless of weight.
Wayne - timmacExplorerMy GVWR is 20500 lbs plus 5000 lbs towing {25500}, so I am 500 lbs under Nevada DMV class A licenses requirements but my actual weight might be over 26000 lbs, I am glad they don't weigh us motorhomes on the freeway or I would be in trouble.
:B - Kayteg1Explorer II
PastorCharlie wrote:
A licensee does not make one a good driver...knowledge and attention is required.
Ask any driver who got his DL in Europe and he will tell you.
I got my DL years ago in Poland.
The exam included knowledge how to change spark plugs, clean distributor, drive curvy road on reverse and merge into traffic. All with stick shift.
Unlike US, punching the brakes and cutting abruptly into next line is not consider merging in Europe. - Kayteg1Explorer II
DFord wrote:
The only bad thing about the driving test is parallel parking these things.
I do have CDL for heavy trailers.
The test involved parking the trailer inside square box painted on test area.
COMING FROM THE SIDE - xctravelerExplorer
Whatever licensee your home state requires is accepted in all 50 states.
Yeah, but when you "move" to another state, to get the license there your current license has to match their requirements, otherwise face the test as we did.
It sure does not make one a good driver, just a legal one. - J-RoosterExplorerWashington State no special license
- PastorCharlieExplorerWhatever licensee your home state requires is accepted in all 50 states.
A licensee does not make one a good driver...knowledge and attention is required. - mtrumpetExplorer
xctraveler wrote:
TX driving test they had us stop in the middle of a quiet side street and back up in a straight line for not more than 30 feet. Not a big deal. Parallel park would be fun :) used to have to do that to get into a parking spot behind my townhouse, and it was on a curve!
Same here in New York. However, he had me back up until he told me to stop. I'm thinking about 60/80 feet. Had to keep it straight within a foot on either side. Had to be sure to first get out of the coach and check out what was behind me, then get back in, check both mirrors blow the air before proceeding with backing. No parallel parking for the test.
Oh BTW...for those considering going for their "special" license...always drive with both hands on the wheel! I had gotten a "polite" warning about that from the instructor on one turn I made. It was the very last turn at the end of the test. He was a nice guy so he didn't bother me about. - xctravelerExplorerTX driving test they had us stop in the middle of a quiet side street and back up in a straight line for not more than 30 feet. Not a big deal. Parallel park would be fun :) used to have to do that to get into a parking spot behind my townhouse, and it was on a curve!
- DFordExplorerThe only bad thing about the driving test is parallel parking these things.
About Motorhome Group
38,707 PostsLatest Activity: Feb 17, 2025
