ggrotz
Sep 22, 2017Explorer
stabil
does putting stabil in the gas tank resolve the problem with the bad gas and return the power that it had before? thank you.
jerseyjim wrote:
During winter (when I'm not snowbirding,) I fill up my 75 gallon gas tank and dump an entire bottle of Sta-bil in it.
jerseyjim wrote:
During winter (when I'm not snowbirding,) I fill up my 75 gallon gas tank and dump an entire bottle of Sta-bil in it. Then I run both the engine and generator for maybe 10 minits to make sure the Sta-bil is "in the system".
During this (storage) time I go to the motorhome every two weeks and start it up (the generator also) and let them run for 1/2 hour or so.
Keeps the batteries charged, etc., etc....y'never know when you might need it.
What I do...FWIW.
SidecarFlip wrote:
Tried one bottle and it did nothing that I could discern for my small engines (except cost a lot).
C20 wrote:
Use sea foam. It will last much longer than stabil.
mowermech wrote:SidecarFlip wrote:
Now if we didn't have corn alcohol in gasoline there would be no problems....
Actually, the "rotten" gasoline was a problem long before "gasohol".
C20 wrote:
Use sea foam. It will last much longer than stabil. Also as others have said use gas with no ethonal in it. It will last longer to begin with. But eventually all gas will go bad if it sits for years.
