arcticgps
May 07, 2015Explorer
Still getting voltage on circuit with fuse removed?!?!?
I ran into a little bit of wackiness while troubleshooting a problem with my power converter.
I pulled some fuses to isolate a problem and then tried to turn on some devices. I found that without the fuse in, my lights still lit. They are LEDs and were dim, Hmm very odd. Multimeter attached showed 13.4 volts when the fuse was in an just over 9 volts when I removed it!!
This is really bad!! I expect undervolting the info panel or even my LED lights would be bad.
Anyone have a clue?
Will
Anyone have a clue?
Will
