Markiemark32
Oct 27, 2015Explorer
Sunseeker Flooring
Hello,
Have a 2014 2690s a year and 8 months ownership.
Earlier this year, started to have a bump in the floor, which is now getting worse.
One of the screws or bolts is backing out and pushing up on the Beauflor flooring, actually pulling up the flooring, now getting super taught, and will eventually tear up our flooring.
Running my hand along the area, I believe there is a seam of the sub-floor, actually may feel other screw heads in that line(not coming up yet).
Attached is a diagram of the location of the bolt coming up arrow & line where I think there is a joint.
Local repair RV shop, suggested cutting the floor in that area to see what is going on and then gluing the floor down there. They said pulling up the flooring and then re-using it, is not an option.
From the underside, the subfloor cannot be seen at all.
Bummed this may be a structure issue. Slide flexing the floor (although we are very consciences of only using slide when level)
I dropped a message to Forest River warranty, hoping to get some guidance, no information on that route.
Has anyone experience this? Or any experience on floor work through the Beauflor flooring.
Any info on the subfloors in the Sunseeker’s?
Thanks,
Markiemark
Thanks,
Markiemark
