DavidAddison's avatar
DavidAddison
Switch on dashboard
HELP PLEASE!
I bought a used 2005 Landau by Georgie Boy. I found a switch on the dshboard that i can't figure out what it's for. I've seen it on "For sale" videos when the show the same year and model. The button is a red toggle type switch located on the left side of the steering wheel. The toggle only gets power when I use the engine batteries, and it'll light up when its getting power. Does anyone know what it sends power to ??
  • Sounds like you got your answer, but sometimes motorhomes come pre-wired for certain accessories. That pre-wiring may include a switch already installed that is hooked to nothing since the optional item wasn't installed. For example, my motorhome has power sunshades. I looked at another model when I bought mine that did not have the power sunshades, but the two switches were installed on the dash hooked to nothing and not labeled.
  • Make sure that you turn it off after use since most mirror heaters do not automatically shut down and will drain your batteries in a short time if left on.
