Television's not working
GHOST1750
I had flat screen TV's put in the motor home a few months ago. The one in the bedroom works great but the 32" in the front worked a couple days and quit. It would come on and we could watch it for awhile then it would go off then back on then off again until it went off and stayed off. The TV was purchased at Costco. My RV service guy returned it and installed another one. It lasted for one trip and part of another then started doing the same thing. He called me yesterday and said Costco didn't want to exchange it because it has been over 90 days. The TV is an LG and when it works it works great and has a beautiful picture but when it doesn't it is a real pain.
I even tried plugging it into a different outlet. The old TV always worked until it became obsolete.
I'm wondering if anyone else has had a problem like this or if you may have some idea what may be causing it.
Just Don and a Chiuahua called Dulce
2003 39' Tradewinds LE
2002 Cavalier tow
Korean Veteran, USAF
FMCA F357981
CC4C
GOOD SAM
Life is a journey, not a destination !
12 REPLIES 12
rgatijnet1
I know it is pretty basic and the repairman has probably checked it, but on our TV the power cord plugs in to the back of the TV the same as on a computer. Our power cord eventually worked loose and was causing intermittent operation. It was not until started to remove the set that I found the problem. I made sure that the cord was shoved all of the way in to the TV and secured it with a cable tie to make sure that it did not work loose again.
GHOST1750
Latest on the LG TV problem. Talked to Duane's RV repair yesterday. It was an LG problem, not only in my TV and my model but several other LG models. One of the power strips in the computer consisting of five pins, one of the pins was shorting out. LG sent a repairman out to the motor home to correct the problem. So if anyone else on the forum or anyone else who owns an LG you know you aren't doing something wrong or going crazy.
2002 Cavalier tow
FMCA F357981
CC4C
GOOD SAM
wa8yxm
I have that problem with one device here.. It kept operating the box (in this case it is the remote for a digital converter) causing a channel change mid-show.. I finally boxed it in a container that prevents it from operating the device... The container also protects it against accidental button pushes.. So far it's worked great (It is a cylinderical container so no way can a button be pushed).
ArchHoagland
One time we bought a new Samsung LCD. It would come on by itself at random times and go off at random times.
Mentioned it to my next door neighbor, who had a new Samsung, although not the same model, and he was having the same problem.
We experimented and our remotes were causing the problem. I was surprised because it had to go through two stick house walls but that turned out to be the problem.
2004 Monaco La Palma 36DBD
Workhorse W22 8.1 Gas Allison 1000, 7.1 mpg
2000 LEXUS RX300 FWD 22MPG 4020 LBS
US Gear Brakes
Bill_Satellite
You need to run a power cord from the TV to a ground based electrical outlet and verify the issue remains. If not then you have an issue in the coach electrical circuit. Yes, I have seen it.
Can't we all just get along?
GHOST1750
Thanks everyone I'll share this information with my repairmen
2002 Cavalier tow
FMCA F357981
CC4C
GOOD SAM
Ivylog
I have a 40" LED Philips in a outside bay that likes to start turning it self on/off/on/off on hot days. More than likely it's an overheating power supply and it's out of warranty so I added a 120V computer fan to the hottest area. Works fine now, but at some point it may stop working completely.
OP, try blowing air on the back of the TV and see if this helps.
Upgraded with a 08 HR Navigator 45’...
ryanallie1
Hi All.
We have had a 26 inch LG LED TV in our Motorhomes upper front area for the past 3 years. Not so much as one problem. As with everything, I have done al of my own work on every RV we have ever owned in the past 46+ years.
We have never "Broken Down", and we have never had a "Flat Tire" or a "Blow-Out", in all of these years. Of coarse I am a "Proventive Maintance Freak".
The biggest problems with any RV, a Travel Trailer, 5th Wheel Trailers" or a Motorized ones. Most problems are usually Electrial issues. I know I'm a nut case. But I do believe if you take good care of your "RV", your "RV" will take good care of you.
Think of all the "Shaking" and "Rattling" and "Bouncing". These RV's tank in just one year. If everyone really checked their RV's, I mean really check every thinig, you would be surprised at how many wires
you just might find lose.
Good Luck. Happy Travels. Dan & Jill & Two Small "Yorkies Kids" who love to travel as much as we do.
1998-34 ft Rexhall, Rexair SL. 460 EFI. F-53. 7.3 MPG. TST TPMS. HWH Levelers. 5.5G Gen. Convection/Microwave Water Purifier/Water Softner. 2 A/C's. Alarm Systems. Honda EU2000i's W/Kit. Steer-Safe. CR-V W/SMI System. FMCA #F414397 Nam-Vet, 66-67-68&70-71
therink
Not that this your situation but I had a brand new LED flat screen TV in my house that was shutting off sporadically. The TV was I'm front of a window that faced the west. It turned out it was overheating from direct sunlight hitting the rear of the set. I put a piece of cardboard behind the TV to block sun and hasn't turned off since.
Could it be that your TV is getting hot? Just a thought.
Steve Rinker
Rochester, NY
2013 Keystone Sydney 340FBH 5th Wheel, 12,280 lbs loaded (scale)
2015.5 GMC Sierra Denali 3500, SRW, Duramax, CC, Payload 3,700 (sticker- not scaled yet)
Take my posts for what they are, opinions based on my own experiences.
dougrainer
Are you POSITIVE you have the TV in consumer operation mode and NOT in Store Demo mode? THAT is a symptom of in Demo mode. Doug
ArchHoagland
It looks like you aren't the only person having this problem.
LG turns off.
US Gear Brakes
trnfla
Sounds like you will need to take it in under warranty for repair. I would ask them to tell you what failed to help you figure out if the problem is electrical or through the antenna port.
Now 2004 Winnie Minnie 31C
Had 2007 Zeppelin 190 Hybrid,
1999 30' Dutchman Classic FW
