Cobra21
Sep 25, 2020Explorer
coolmom42 wrote:
Number 1 thing is to decide on a budget. Be sure to include enough for taxes and registration. Also allow for critical things after you need it, such as tires, or appliance replacement. You will also want to have some funds for general setup, such as dishes, bedding, etc.
Number 2 thing is that it have no water leaks. Go over it with a fine-tooth comb.
Number 3 thing is that you and your wife are going to be happy in it.
*Are you agile and willing to use the over-cab bunk? Does one or both of you get up a lot at night? Consider bed access. Consider that you might split your sleeping arrangements, if that is something that will make life simpler.
*Does it have a comfortable place for both of you to sit? Consider if you are computer users or TV watchers or hobbyists. You want a spot to do all of that and a standard dinette is probably not going to be comfortable for 2 people to do things. Maybe look for a sofa, or a setup where you could readily replace the dinette with a loveseat or twin recliners.
*Are you people who can travel light or do you have to bring the kitchen sink? Take into consideration the inside storage.
For 2 people IMHO the best floor plan is going to have a slide-out so you don't fall over each other all the time while trying to cook, eat, and move around in the RV. That gets really annoying. I do not have a slide but I am mostly by myself.
There are lots of tips for pre-buying inspection checklists. Do your reading and learn about what to look for.
Decide on your parameters and set up alerts on RVTrader. Be willing to wait a while to get exactly what you want.
Yes, Yes, and Yes! This pretty much sums it up!
Brian
38,705 PostsLatest Activity: Jan 14, 2025
