Malone wrote:
Hi there-
Any thoughts or comments on 2015 Thor Majestic 23a please?
Were they made specifically for Cruise America? They seem to differ from 23U.
How do they drive on dirt roads?
We are looking at one for sale by a local rental company.  111,000 miles.
Thanks for any input!
We don't have a Thor Class C.  Ours is 24 foot Itasca (made by Winnebago) Class C that we take slowly and carefully on dirt roads.
Remember that unlike much lighter 4X4 "offroad" vehicles, a Class C has way better dry surface traction on it's rear drive tires due to the raw weight back there.  Of course on wet/slippery road surfaces, both a Class C and 4X4 vehicles can slip and slide around, plus get buried up to their axles.
We have installed larger than stock diameter tires on our Class C in order to provide more ground clearance on dirt roads.  We cross road washout areas as much as possible at an angle in order to prevent rear tail dragging.
It's easy to keep the interior clean when on dirt roads:  Keep the cab heating/cooling system set to "interior" air flow so only inside air is recirculated - with no outside air being drawn in.  Keep all windows and roof vents closed - except for one roof vent with a reversible vent fan in it. Set this fan to blow in on low speed.  This sets up and maintains a slight pressure in the coach interior so that no road dust can enter any small holes and cracks anywhere - this works like a champ because (nearly) no outside air is actually brought in because everything is closed up. (What little air is actually brought in due to leakage out holes and cracks is clean air from up high above the roof.)  The fan is merely "trying" to force air in, so what results is the maintaining of a slight amount of air pressure in the interior at all times.
