Tire air chuck for duel tires
Buster52
I remember a tire hose kit that aired up both back tires on duel tire at the same time. So both tires have the same pressure. I also remember kits that filled all four tires at the same time so all rear tire had the same pressure. I cannot find them anymore. Does any one know where I can find them? And is there a need to be that close in pressure?
Thanks
8 REPLIES 8
mpierce
I have run Cross fires on semi trucks over 2 million miles personally. LOVE THEM. Pressures are exactly the same. I have seen a chart about the tire wear when pressure is only a couple pounds different in a set of duals. They have a check valve in them, so that if one tire has a leak, it will seal, and not allow air to drop over 10# in the other tire.
I got better tire life, and tire wear with them, both on my semi, and on the trailers.
Also made it very easy to check pressure. Just take a glance at the face of them, and if in the yellow, good to go! Turn black if under pressure, red if over.
wa8yxm
all 4 tires, no such kit exists, that is a major modification to the RV, and may not be the best thing for you.
With tires, epically the rear ones, it is important they all present the same RADIUS (and by that I mean the distance from the center of the axel to the road surface) and that may require the right and left side be different pressures.
Cross-Fire dual tire inflation/monitors http://www.myerstiresupply.com/shop/shopexd.asp?id=746
May be what you are looking for, they come in assorted pressures, I am unable to install on my coach.
Why would a "All 4" System be all but inmpossible,, Well, the side to side crossover needs rotating seals, and there is not a practical way to do that less you drill out the length of the axles.
Buster52
I have seen the $150.00 per set. This item was just two shout pieces of hoses connected to a Y that screwed onto the valve stems and had a tire schrader valve to add and remove air. It was around $15.00 at the time. I am making one up, but it would be a lot cheaper probity better to just buy one.
10forty2
Being somewhat gun-shy from 2 separate tire failures in less than three months, I'm a bit intrigued by this. Anyone with first hand experience using a Cat's Eye system? If so, then what criteria do you use to get the correct pressure system? Do you go with the max inflation listed on the actual tire? I notice that there are multiple models available to cover both the tire size and the pressures.
I've seen them on tractor-trailer rigs, but not ever having a dual tire configuration before owning our coach, I really never gave it a second thought.
1999 Holiday Rambler Endeavor, 36' Gasser
Triton V10, Ford F53 Chassis
lj2654
Iowa80.com has them in their catalog...all different pressures...
2001 Beaver Contessa Naples 40
2012 Cadillac Srx
retired AirForce 1979-1992
wildtoad
Do a Google search for Crossfire dual tire equalization. I don't remeber one that would do all four but maybe there is. And I don't think they need to be 100% exactly the same.
Tom Wilds
Blythewood, SC
2015 Jeep Wrangler 2dr HT
donn0128
Check out any large truck stop. Truckers use them all the time.
gbopp
Something like Cats-Eye?
