- wearenhExplorerThe TST (and EEZRV, and all other TPMS) are not stems, they are caps ... see pics
I recommend the EEZ brand... the pics below show the sensor caps with the
anti-theft housing ... if you remove it as I did (living life on the edge), the
sensors are the smallest of any TPMS sensors, and the system works great
EEZ TPMS Systems (we have 10 sensors: RV + Trailer) - BobboExplorer IISince each tire only has one valve stem, how can you install both the Tireman stems and the TST stems?
- ADORExplorerAt least at the CW where I purchased the Borg kit, NO. Part of the reasonI returned it. Im here at Discount Tires right now having my Tireman Metal Valve Stem Kit (Not extenders) and TST 507 internal, strap mounted sensors installed. Getting ready for 3 week road trip.
- PonderosaExplorerDoes CW do the install on their valve extenders? $$?
- WA7NDDExplorerI put Tireman valves on my E350 two years ago. So much easier to deal with the tires. First time you air up you'll be glad you got them. I added the M66 Tireminder to them this month. Was so nice to just screw the transmitter onto a strong valve stem out in the open with no hassle. Worth every cent.
- IAMICHABODExplorer II
Baja Man wrote:
are these the Tire Man extenders people are referring to?
Tire Man
Yes they are the ones. - Baja_ManExplorer
- ADORExplorerBorg's kit from CW have great quality. However, I have decided to return it because I need a Full Kit for front and rear. I purchases the Tireman kit. Also great quality. They also came with the oval rubber support (x2) for the outer wheel.
Both kits are great. I have seen both kits. Just a matter of preference on which kit you want. - Baja_ManExplorerGreat....I think I have it figured out. CW price is pretty good for the rear duals. Need to find a set of fronts as they are not avail from CW.
- j-dExplorer IIThe cap linked above is what I to in your other thread, V2B, Gator, Crocodile. And YES, you found the right set of Dually Valves.
About Motorhome Group
38,709 PostsLatest Activity: Mar 09, 2025
