Mich_F
May 16, 2018Explorer
Off Pavement wrote:
I'd recommend checking the tire manufacturer's recommended load and inflation tables. To do so requires getting actual front and rear weights and for my vehicles actual loaded weight, I run 55 front and 65 rear.
I would suggest bumping up your front tires to 60 psi (assuming you're running E and not D tires). I believe that you shouldn't run your tires at less than 75% of the max psi for the tire. Might not be true, but why take a chance, since it will give you more of a cushion and probably won't affect the ride quality. ;)
