bzp
Apr 25, 2017Explorer
Tire pressure issue
Seeking advice concerning the best tire pressures for my motorhome. I have a 2004 Winnebago Journey that is built on an oversized Freightliner chassis. The chassis GVWR is 27,900# and my coach weighs in at 21,180# fully packed and filled with liquids. I have Goodyear G670RV tires (26575R22.5G). Winnebago says I should have 100 psi in the rear tires and 105 psi on the front tires. I checked the Goodyear website and found that the 100/105 psi recommended tire pressures would be right if my coach weighed 29,519#.
I believe the Winnebago recommended pressure is too high because it was selected to cover my GVWR rather than the actual weight of my coach. The Goodyear inflation / load charts say I should use only 75 psi.
What is the best pressure for my tires? I believe a reduced pressure will give me a smoother ride but I question how the reduced pressure will affect my steering and handling. I am also concerned about making such a significant change without advise from other experts.
Does anyone have experience and recommendations?
