dotcommer
Aug 13, 2018Explorer
Tire Pressure Questions on my Michelin XRV 255/80R22.5
I was wondering the proper way to calculate proper tire inflation based on the manufacturer's ratings.
I currently have the Michelin XRV 255/80R22.5
BELOW IS THE MANUFACTURERS SPECS
Per the Michelin website
Max Load Per Tire Single 5205/110 lbs/psi
Max Load Per Tire Dual 4805/110 lbs/psi
Loads per Axle End
PSI SINGLE,lbs DUAL,lbs
75psi 4070 7410
80psi 4300 7720
85psi 4440 8080
90psi 4620 8410
95psi 4805 8820
100psi 4975 9050
105psi 5150 9370
110psi 5205 9610
I had my coach weighed at a truck stop with a full load during my trip two weeks ago. This is the results
Steer Axle : 8020 lb
Rear Axle: 15840 lb
Questions:
Do I take steer axle weight of 8020lbs and divide it by 2 so it's at 4010lbs per tire? And the same for the Rear Axle 15840/2= 7920
Those numbers seem too low for tire inflation based on my weight especially since my total gross weight was 23860lbs which I believe is the max for my Thor Challenger 37tb
Any feedback would be great, thanks.
Loads per Axle End
75psi 4070 7410
80psi 4300 7720
85psi 4440 8080
90psi 4620 8410
95psi 4805 8820
100psi 4975 9050
105psi 5150 9370
110psi 5205 9610
Rear Axle: 15840 lb
Questions:
