When traveling with your RV your maximum tire pressures are 110 when it reaches 110 is the general rule of thumb to stop and lower the pressure back to the starting point of 90 to 95 psi? I just bough...
Your tire manufacturer doesn’t recommend lowering the tire pressure, does he/she? Tire pressure is set with cold tires. Almost all weather conditions will cause a working tire to increase its pressure.
