strudeau
Jul 11, 2013Explorer
Toad Wiring Issue
I have been running a six pin connection to my Toad for my tail lamp, stop, and turn signals. Everything worked great until i just installed my Air Force One Toad Braking System. The Air Force One works great but now I have a brake light issue (turn and tail lamp work fine). Just to clarify, when you install the AFO, you tap into the cold 12 volt line that is adjacent to the brake peddle, this line goes hot when the brakes are activated. Anyway, I now have two sources of power for the brakes and I suspect they are grounding out each other because I now get my left turn and brake light activating, the right brake light functions normally.
My question is, which of the two sources should be disconnected? Has anybody run into this on a Air Force One Install?
Thanks in advance.
Thanks in advance.
