Tow Haul mode
ntar827
Have a Chevy Class C.
Do you normally drive with the tow- haul engaged or not?
Does it help of hurt on downhill grades?
Thanks
Nick
18 REPLIES 18
powderman426
I can't speak to gmc, but on Ram trucks, the T/H mode is different by year. My friend has an 04 and T/H keeps it from going into overdrive while my 05 is the opposite. I would try to find someone with the same year. JMO
Ron & Charlotte
WD8CBT since 1976
32' Gulfstream Ameri-Camp & 05 Ram QC LB
I started with nothing and I still have most of it left
I never fail, I just succeed in finding out what doesn't work
Not_a_Clue
I have mine on most of the time, but in Southern Ca we are going up and down hills most of the time.
Linda B.
Our Blog
2009 29' Fleetwood, Fiesta V10 - The Little Bus
2008 Saturn Vue (Toad)with US Gear UBS
& Demco baseplate and tow bar.
FMCA# F412985
Traveling with Robin(friend)& Buddee(cavalier)
dan-nickie
Only use in in the hills.
It helps keep the speed down while descending.
Dan and Nickie
2014 Forest River Berkshire 390RB
the_bear_II
I use it on hills or if I'm towing something.
It won't hurt the engine/transmission to use the tow haul(T/H) mode all of the time. Basically it keeps the trans from shifting into overdrive. Overdrive provides better gas mileage on mostly level roads.
If you always use it you may use more fuel. Try a couple of test runs with it engaged and calculate your mileage and then try the same route and only use the T/H mode for up or down hills, compare your mileage.
