Jul-22-2022 01:57 PM
Jul-25-2022 02:04 PM
Jul-25-2022 05:20 AM
Jul-24-2022 09:23 AM
wa8yxm wrote:JRscooby wrote:
I would say this is pretty good info except this;
(Be very careful they are not designed for 8 1/2 foot wide RV's
You are right, they are NOT designed for RVs. They are designed for trucks, and most semi-trailers are 53 ft long, and 8 1/2 foot wide. And most places the scale is designed so a driver can get off/on with a long and wide load. If you think you need to take extra care driving thru scale, how do you keep it between the curbs thru town?
The one thing you may need to watch is the divides between segments, to get steering, drive and toad each on it's own.
Well. the standard width for a "Lane" on a road is 12 feet (Some are a bit wider) Truck Scales (like the CAT) average 10-11 feet so you need to be more careful.. I'm not sure Cat Scales are that wide.
You are correct about the length however.. I was referring to "Side to side" you need to be careful about centering side to side.
Jul-24-2022 06:48 AM
Jul-24-2022 05:21 AM
wa8yxm wrote:
How much will a Gasser Class A tow?
Good question and there is no FIXED answer
Generally the hitch receiver on a Gasser is rated 5,000 pounds
This assumes a Straight hitch. No rise/drop adapters. And no extenstions
(Those deices de-rate the receiver's rating)
BUT. wait there is more Oh yes always more
Your motor home has 3 Weigh numbers you need to know (Well you need two of them for this)
Max GVW (Maximum weight of Motor home. Full fuel tank Full Fresh water.. Loaded for travel should NOT exceed this number)
Next is MAX Combined Groos Vehicle Weight (GCVW)
This is weight of Motor home as above... PLUS anything you tow.
IN my case the MAX CGVW was 26,000
The actual weight of the Motor home as scaled fully loaded for a trip
In my case 22,000
Now take the last and subtract from the one above it and you get 4000 pounds IN MY CASE.
You will load differently from what I did so your figures will be different.
Also your Motor home may have a greater (or lesser) "Dry" weight. (the weight of JUST the motor home as it is delivered before addition of Food. Water. Clothing. Other stuff and occupants)
So Your question can only be answered by you
For how to weigh your Rig.. Three ways
CAT scales found at many truck stops (Be very careful they are not designed for 8 1/2 foot wide RV's WIll give you both axle and total weights.
With a FLAT segmented scale you can get Induvial wheel weights. (ALso axle and total)
RVSafety dot com has a weigh your rig link (Have not visited in several years)
You call them. (Have the make, model and size of your RV's Tires handy IE: Mitchlin XRV 22.5 x whatever) and they come armed with the Tire's weight chart
Then they use portable scales to weigh each wheel and tell you how many PSI should be in the tires.. NOTE I believe each tire may be different. Some say that all tires on a given axel should be the same.. I won't argue Just pointing out I disagree I can explain why.
They may have other suggestions.. I used this service.
Some Weigh Stations (Depart of Transport) leave scales on when closed
ANd you can alwyas buy a beer or two for a Weighmaster
But only the RVsafety folks come armed with the tire charts (you can download those from the tire maker_)
Jul-23-2022 03:09 PM
Jul-23-2022 06:02 AM
Jul-23-2022 04:39 AM
Jul-22-2022 07:04 PM
Jul-22-2022 06:01 PM
jts140 wrote:
Anyone towing a Jeep Grand Cherokee (Trailhawk) with a gasser? My Jeep weighs almost 5k and was wondering how a Gas Class A would tow. Would be towing to the Denver area from Florida and up to Breckenridge Area numerous times. Son has just moved there. Thanks for any info.
Jul-22-2022 04:01 PM
Jul-22-2022 03:05 PM
Jul-22-2022 02:55 PM
Jul-22-2022 02:18 PM
